NGK B8ES vs BR9ES: more easy revving?
Problems with the RD? Please post.
Teake
Beitrag von Teake »
I have a 1WT (1WW in Germany) which didn't rev happily above 8000 rpm. Now I saw the sparkplugs have resistance (BR9ES, nearly new) AND the sparkplug-caps have Resistance. So I changed the sparkplugs to non-resistance ones (B8ES, aprox. 3000km old)) (and with a slight warmer number).
<BR>It seems to rev more easy now. Can this be because of the other sparkplugs? It could be the resistance makes the spark a little later...
<BR>Oh, I also synchronised the carb-slides: the right one was 2mm lower than the left one.
No, the better revving is a result from a higher combustion temperature due to the changed heat rate of the plug.
Teake
Beitrag von Teake »
Vielen DANK! Ich Hätte nie gedacht dass so etwas so viel Drehfreude unterschied gibt!
