392 ypvs engine upgrades
Problems with the RD? Please post.
marsbar
Beitrag von marsbar »
this is where i am up to now
new pwk 28s fitted
new stator
athena barrels
sispeed
Beitrag von sispeed »
Hello,
think this thing delivers a lot of HP if it is ready to run.
Keep us informed.
Regards Siggi
marsbar
i will
hoping to get between 65-70 bhp
have some hydro formed pipes made coming this week
using a 4LO wiring harness,switch gear etc
ignitech ignition and stator.standard F2 flywheel
triumph t595 brake calipers
marsbar
got some digital clocks from china took a week to arrive and only cost £39 delivered
still needing a F2 petrol tank !!
hopefully first fire up this weekend.will post some pics then
thes are the clocks i got for it.cant find the original link
exactly the same
http://www.ebay.co.uk/itm/LCD-Digital-S ... 1c457c62ef
sispeed
Some parts from China are really cheap but good to use.
Looks really good.
Hope your first start is a success. I know the feeling of being so curious about the first start.
Good luck
marsbar
the bike started first try
so pretty happy
will post some more pics soon
i now have a petrol tank
has anyone got a f2 petrol tap
thanks
sispeed
You should ask for parts in this column
http://forum.rd350lc.de/viewforum.php?f=24
Thats the column for parts search.
marsbar
hanks sispeed
heres a few pics taken last week,spent all day on it bleeding brakes and wiring and got it running
pipes on oil pump fitted
clocks fitted.using a 4L0 loom so fitted lc switch gear.31k handlebars and top yoke
carbs adapted to use a 4L0 throtle cable
sispeed
Did you calculate and build the pipes?
If so how did you build the sections. Looks like pressed and only weld two halves together
From the first view it looks a little bit like Spec II
Really nice build
marsbar
thanks sipspeed
the pipes were built in kit form by a guy called martin johnson
front part was hydroformed and the rest sent in kit form
a friend welded them together at my house
we sent him the port maps and made to suit
cost £235 mild steel construction.will paint them high temp black
frame is an F2 plus forks.31k top yoke 350r top fairing
Yep, looks great. Keep on posting.
:thumbup:
marsbar
thanks kilroy
i have sourced a tank getting it blasted the painted
going to be all black
same as my LC swop number plates on them to get some miles on it before track day here :https: https://angleseycircuit.com/fixtures/welshclassic
marsbar
good news with the tank
no dents or holes.pics are after its been blasted
marsbar
managed to get the bike on the road for a quick spin
got to bleed the front brake again
should be painted in the next 2 weeks.wont say what colur scheme its a secret!!
here some pics taken after the first ride
marsbar
had to doa [etrol tap alteratiom as the internal pipe feed was hitting the airbox and beending the fuel pipe too much
drilled out and replaced the outlet opposite
hope fully it works
