Main bearings
Problems with the RD? Please post.
NickIrons
Main bearings
Beitrag von NickIrons »
Does anyone know of a good supplier for
a set of outside main bearings for a 4l1,
in either Germany or Switz?
I can get them from England but the postage
is a bit high.
Thanks, Nick.
And the same message in German, may be all
wrong though!!!
Weiß jemand von einem guten Lieferanten für einen Satz Außenseite Hauptlager für ein 4l1, entweder in Deutschland oder in Switz? Ich kann sie von England erhalten, aber das Porto ist eine hohe Spitze. Danke
MatthiasD
Beitrag von MatthiasD »
Hi Nick, do you mean the left bearing on the output shaft of the gearbox or the right & left outer bearing of the crankshaft?
NickIrons
Hello mate,
I mean the two marked on this pic as
"These two" Ignore the rest of the text
on the pic.
Have a look here: http://www.brc-racing.de/
Outer left and middle bearings:
50078 Lager KW 2009 Pin RD 350 Pro X 24,75 Eur.
Outer right bearing:
50079 Lager KW 2010 Nut RD 350 Pro X 24,75 Eur.
MatthiasD
That's cheap! The right one with groove is a standard size but quite expensive if you order it from your normal bearing supplier (40 euro's)
The other ones van be had cheaper (without the pin) but still a good price!
hasi
Beitrag von hasi »
Take standard-bearings from FAG or SKF..
These are without pins, put you dont need any :wink: :wink:
Ordernumbers:
6305-C3
6305N-C3
NickIrons
hasi hat geschrieben:Take standard-bearings from FAG or SKF..
Ordernumbers:
6305-C3
6305N-C3
Nice one cheers!!
Are the order numbers the same for SKF
and FAG?
Thanks, Nick.
schrauberlehrling2
Yes, these bearing numbers are the same with every brand i have seen. Sure between FAG and SKF.
Maybe a good idea to use a brand proven to last. More exact, there are bearings with different load and rev capabilities, also the make of the "cage" is sometimes different.....
However the most important thing is getting ones with the correct tolerance(-C3).
Florian
