convert banshee to oil pump?
Gast
Could get tricky ...
<BR>As I've never looked inside the banshee cover I can't tell wether it has the neccesary bearing locations for the ouil pump shaft.
<BR>So I guess you need the complete right engine cover from the RZ350 (=RD350YPVS). It contains water & oil pump which are both driven from the additional gear on the right outer side of the crank.
<BR>But why don't you use the complete YPVS engine anyway. It's a plug & play job ...
