long rod banshee
hi there,ive got a banshee and want to make a longrod motor from her,can i use rods from an rd 400 on the banshee crank,as i understand they are 5 or even 10 mm longer,and then blaster pistons cos there not as tall as banshee pistons,can someone enlighten me on this cos im dead confused,will the rd 400 crank fit a banshee????? see ya,thanks.
I don't think that anyone on this site can help you.
<BR>The RD400 crank doesn't fit in the RZ case. But there are many stroker cranks for RZ/Banshee on the market (check: trinityracing.com, rd350ypvs.de, soni-x.de)
<BR>If you ask me: get an RZ YPVS engine incl. harness & CDI & YPVS unit - this are the cheapest + 10-15 extra HP that you can get! The effect is much higher than "just a crank".
<BR>PS: If you don't already have it: I can recommend a good manual on tuning RZ's ...
<BR>(http://cgi.ebay.com/ebaymotors/ws/eBayI ... gory=34239)
<BR>Ciao
<BR>Martin<BR><BR><font size=-1>[ Diese Nachricht wurde geändert von: MK am 2004-05-25 16:37 ]</font>
<BR>Ciao
Check this out:
<BR><!-- BBCode auto-link start --><a href="http://www.macdizzy.com/1ban.htm" target="_blank">http://www.macdizzy.com/1ban.htm</a><!-- BBCode auto-link end -->
yeh thanks,the problem is with the street alowness,im not realy allowed more than 20 hp,but i have!! but i want even more,ypvs motor is too obvious to the cops! i know macdizzys too,anyway ive ordered my blaster pistons and 400 rods and i send the jugs off to stan stevens,(trinity are grenades!) for a stage 3 tune,bore carbs out,kn filter and paul turner pipes,dyna ignition,should do the trick,you see it must look standard from the outside,thats why i bore the original carbs out and paul turners in black look less inconspicuos as fmf ect. thanks for the answers guys,anyone ride banshees in bayern here?
